hey guys need your help here. my car is loose off gas it fells like the the car just unloads as soon as i lift off gas. it wants to spin around. it has a pullbar and brake shock. already have my lrf shock at 7c 2r. just needs some ideas here. car is pretty good.i took some bite out but seems to make it worst.
loose off gas! need ideas!`
im sorry i read your rear springs backwards.....i think wat u have is probably ok.....but id look at the front springs, having the rf stiff especially will take away side bite on entry because when the car rolls on the right side the rf will carry more of the load then the rr
Check the square of the rear end in the chassis. Make sure the RR is not trailing. Also, make sure the rear is not bent, i.e. toe'd in or out. Take stagger out if you have a lot. Soften those front spring rates and reduce the spring split. Maybe 700LF 650RF for example. I'd also soften the rear springs up to both 200's or 225LR 200RR. Make sure you don't have too much LS and/or LR %. Go with 50/50 shocks until you get the car handling better.
